跳转到主内容
加入维修社区 - 创建账户
1:10 比例遥控蝙蝠车及人偶,支持通过智能手机 App 进行第一人称视角(POV)驾驶。型号 #FKM40
How to repaint Ultimate Batmobile?
Is it possible to disassemble the toy? I want to repaint it.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
sponge brush and cheap coal black acrylic black paint will work. lightly clear matte coat spray paint and its done. if you want more then youtube how to “drybrush” and use that to apply gun-metal gray and silver to the body for battle damage. good luck
这个答案有帮助吗?
得分 0
添加一条评论
The base colour is pretty accurate to be fair. The batmobile is not black, it's a dark grey. I have studied lots of pictures to get my repaint as accurate as possible. It's also worth noticing just how beat up and dirty the batmobile is too. So, using acrylic paints from Vallejo I have extensively drybrushed silver all over it to catch all the edges as well as put scuff marks in any points where you'd expect the batmobile to get battered. The silver was also used to paint the ammo feed belts prior to black was and then silver drybrush.I have also used black to paint some streaks of dirt on it as well as used a piece of sponge, dipped in black paint and then dabbed on to great a mottled, grimy appearance, again all over but build ups in places where the dirt would be splattered on e.g. leading edges of mudguards, all over the back end etc. I also used thinned down black to create a wash that I used to bring out details prior to silver drybrushing. Note that the missile tips in the two side pods behind the cockpit, and the stripe around nose of missiles in the front pod should be orange. lt's taken time but the end result looks incredible and looks like it's straight out of the movie!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mel Dipad 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 28
总计 576
