跳转到主内容
加入维修社区 - 创建账户
Motorola Moto Z Play(型号为 XT1635-02、XT1635-01 和 XT1635-02)是一款于 2016 年 9 月发布的安卓智能手机。Moto Z Play 的外观特征非常明显:机身正面顶部印有“moto”字样,底部配有一个方形主屏幕按钮。
How to remove stripped screws?
Hello, I am trying to replace a battery on the moto z play phone. I got the back off and screen separated. But can not get the little screw out to remove the metal piece holding the battery cord in place. Anyone have a suggestion on removing stripped screws? I have tried the rubberband trick but no luck.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
Have you tried other screwdriver bits of different sizes and shapes? If that does not work you can carefully drill into the screw till the head comes off with a very tiny drill bit (see pin vise from here or amazon). Of course with this method you will have to replace the screw.
这个答案有帮助吗?
得分 1
添加一条评论
That was not pretty. I ended up drilling the screws and doing my best to break off the top….which was challenging. I tried the rubberband trick and I think they were to far gone. The super glue did not hold and would just pop off. And then I even tried soldering the screw……nothing.
Anyway, I got the screw heads off and was able to move on.
Thank you for your responses and help. I greatly appreciate it. I am new to this….so lots of trial and error.
这个答案有帮助吗?
得分 1
添加一条评论
Hi Melissa,
A couple of options with stripped screws, drilling is an option as Josh mentioned, but first, to drop a little super glue into the screw, then pop the driver in, wait a few mins then twist out.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Melissa Odom 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 5
过去 30 天: 21
总计 705
