跳转到主内容
加入维修社区 - 创建账户
Game Boy(Game Boy 掌上游戏机)于 1989 年 4 月 21 日在日本发售,随后在 1989 年 7 月 31 日登陆北美地区,最后于 1990 年 9 月 28 日在欧洲上市。它的特点是拥有一个较大的灰色外壳,型号为 DMG-01。
Game Boy Color won't turn on.
There is no corrosion, the switch works fine, F1 fuse is fine, but the F2 fuse isn’t working. Is it this? How do I fix the F2 fuse? And if it is not this, what else can I try?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@thebmax F1 is the fuse for the battery power and F2 is the one for the adapter plug. The fuses should be of type ERBRE1R25V. You want to clean your mainboard with some high grade isopropyl alcohol. The replace the fuses appropriately. Do not forget to clean your power switch with isopropyl alcohol as well since it has an issue with gumming up after a while. Once properly cleaned and the fuses replaced, get a new battery and power adapter and give it a try.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
BMax 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 532
