跳转到主内容
加入维修社区 - 创建账户
PCR 仪的维修、支持和服务信息。也称为聚合酶链式反应仪或 DNA 扩增仪。
Support of Bio-Rad S1000 PCR
The S/n under 10,000 is no longer supported can you guys work on these?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
I have a problem, I was using two PCR (C1000 Touch thermal cycler) at the same time because I'm having many samples, unfortunately, all of them stopped working, and when I switch them on it only ended with SYSTEM INITIALIZATION on the screen.
Can anyone help me how to fix this problem?
Gregory
完成的
添加一条评论
1个答案
Hi Chad,
I had at least couple of these with 1 (that is ONE) faulty capacitor in power supply that manufacturer solution was not to repair but to supply whole board. If your PCR machine doesn’t power on or shuts off occasionally, could be that capacitor C19 100uF has to be replaced. Hopefully you can find someone to do that for you. Make sure that backup battery on the board is NEVER REMOVED!!! because you will loose firmware data and machine will become unusable. If you have problem with the block then i’m afraid there wont be much you can do.
All the best
John
这个答案有帮助吗?
得分 0
1条评论:
how to connect s1000 bio rad thermal cycler to computer?
完成的
添加一条评论
添加你的答案
chad richardson 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 7
过去 30 天: 31
总计 1,189
