跳转到主内容
A mid-range smartphone from Samsung released in 2019.
122 个问题 查看全部
What parts are needed to repair water damaged phone?
Hello,
My phone was only wiped with a damp tissue, not sure how it caused the damage. I started getting the phone is heating message and keeps turning off, even though the phone is cold. I checked the sim slot and the slip was red.
Can someone help me with what parts I need exactly to fix water damaged phone (the usual fix for many people ) , I've read about replacing the battery, but since it was just a wet tissue I doubt the battery was damaged. I would like to leave the battery as the last solution to try. Please refer me to other parts that I should replace before the battery.
And are all the A50 parts the same worldwide?
Help is needed, I would like to purchase them asap.
Thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@andf123 this error message is usually displayed when you have a bad battery. There are no standard parts that will fail since each water “exposure” is unique. You would have to disassemble your phone, clean all parts with something like 90%+ isopropyl alcohol. Check your motherboard for any obviously damaged/missing components. Then replace the battery, reassemble and re-evaluate. Most parts will fit but it will help if we know the exact model of your phone.
这个答案有帮助吗?
得分 2
1条评论:
Thank you for your reply.
I understand, but I read that heat senser could be damaged. Since I already opened the phone and the battery, and surrounding area look clean, no dried water spots or any sign of water was present (I might be wrong), I'll try to check and clean the motherboard but I only have 70% alcohol, I doubt I can find any higher during these times.
完成的
添加一条评论
添加你的答案
And.fix 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 10
总计 242
