Why will my horn not stop sounding
How doing get to the horn switch in the airbag module?
Sounds like your alarm system is setting the horn off. Use your valet key and lock the driver side door then unlock it.
这个答案有帮助吗?
It sounds like the horn button on the steering wheel has the foam padding compressed and when the temperature changes it can cause the horn to go off. You will have to get a new airbag assembly or take out the horn relay or unhook the horn. This is a common problem especially if it gets cold in the area the car is.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 191
1条评论
Can you explain this a little better please. I doesn't make sense.
由 Allan Barr 完成的
