跳转到主内容
加入维修社区 - 创建账户
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
How to fix this boot?
Hi,
My iPhone has no previous backup and while it was on charge yesterday(the battery was flat), the Samsung adopter exploded. Its charging port was now not working. I tried to put the motherboard into another phone and it nows displays the screen but the apple sign stays on like for a minute and it restarts again to show the same thing again.
Is there any way i can fix that without loosing my data?
Thanks a lot..
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
已选择的解决方案
This sounds like you have damaged one of your charging IC’s when the charger failed. This is quite common and can easily be repaired by any reputable phone repairer that offers microsoldering.
这个答案有帮助吗?
得分 1
2条评论:
when i changed the housing of the phone, the motherboard works in the other housing..This means that the charging IC seems to be fine..and on connecting to the cable, it opens but doesn't boot up and connect to iTunes.
If you could help please?
完成的
@Sidick angel So it boots in the other housing and everything works?
完成的
添加一条评论
You can send it to iPad rehab ipadrehab.com they can retrieve data. It costs 300 dollars only if they get the data.
这个答案有帮助吗?
得分 0
添加一条评论
Solution for boot loop in IP7: https://www.youtube.com/watch?v=bQMaqHXG...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sidick angel 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 25
总计 165
