跳转到主内容
加入维修社区 - 创建账户
适用于 iPad Pro (第 3 代) 的手写笔,具备手势控制以及磁吸附和充电功能。于 2018 年 11 月发布。型号 A2051。
Tip snapped off inside.
I purchased a used apple pencil 2nd gen. and the tip is snapped off inside. The end part of the tip that’s a hollow circle. Any ides on how to get it out? I’ve been trying tweezers with no luck.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
1条评论
Can you post a few pics that clearly show things 在已经存在的问题里加入图片
由完成的 分享
添加一条评论
4个答案
最有帮助的答案
I have used a needle and rotate ccw, push pin or something might work too
这个答案有帮助吗?
得分 1
1条评论:
I managed todo this with a sim ejection tool. I just keep turning until it was a little higher and was able to tip it out and put on a new end
由完成的 分享
添加一条评论
Hi
Sorry to hear about your Apple Pencil
Let’s get it doing what it does best!
My advice here would be to get a sewing needle and scratch a small divot into the bit stuck inside until you have enough leverage to start Turing it out!
If that doesn’t work try using a small flat head screwdriver carefully as this method is to be used as a last resort.
If you need any help with it please do not hesitate to ask
Hopefully all goes well for you
这个答案有帮助吗?
得分 1
添加一条评论
Hi, my pencil connects to the iPad when it is placed next to it, but when I want to work with it, it does not work at all and the tip of the pen does not communicate with the surface of the iPad.
这个答案有帮助吗?
得分 0
2条评论:
由完成的 分享
Hi, I have more or less the same issue… Any news on how to fix this?
Greetings!
由完成的 分享
添加一条评论
My pencil snapped inside as well, is there a way to get it fixed ? Or getting a new one is the only option?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Honey Bear 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 12
过去 30 天: 41
总计 5,423
