跳转到主内容
Model A1419 / EMC 3070 / Mid 2017 / 3.4, 3.5 or 3.8 GHz Core i5 or 4.2 GHz Core i7 Kaby Lake Processor (ID iMac18,3) / Retina 5K display. Refer to the older iMac Intel 27" Retina 5K Display (Late 2014 & 2015) guides as the system is very similar.
293 个问题 查看全部
i7 7700K CPU 4.2 GHz
I know that the i7 7700K CPU is now obsolete, but I’ve found one and ordered it! It costs $642 which I think is expensive, especially as it’s gone out of production, but it’s the only i7 that my iMac can be upgraded with, so here goes…
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Thats way to high! You can find them for less! Intel Core i7-7700K Kaby Lake Quad-Core 4.2 GHz LGA and I know that’s still also on the high side.
这个答案有帮助吗?
得分 0
3条评论:
Just picked one up for $300
完成的
@aprstudios - Make sure you align the chip correctly and when you tighten the heat sink down treat it like how you tighten the lug nuts of your cars tires! Are you tightening your lug-nuts in the proper way? Of course we don't need an impact wench! But we do need to be careful we don't over tighten the screws. As an example AMD ships a special tool with there Threadripper chip as its a big issue Ryzen Threadripper tool
You'll also need to use care applying the new thermal paste. As you only need a little! You want just enough to cover the die cover, you don't want it leaking over the sides.
完成的
Yes, I’ve built up a nice overview of videos and texts regarding the CPU upgrade. Thanks again for your help, it’s seriously appreciated!
完成的
添加一条评论
添加你的答案
Adrian Swift 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 9
总计 243
