跳转到主内容
苹果推出的面向个人消费者以及教育市场的笔记本电脑产品线。 iBook 系列包括 iBook G3 Clamshell,G3 12寸,G3 14寸,G4 12寸,以及G4 14寸。
Freezes after keyboard replacment
I installed a new keyboard in the 12 inch ibook, now when it is powered up the screen freezes. I took it apart to check and all steps followed found everything as ifixit showed. Could it be the keyboard or something I might have done?
Cindi
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
3条评论
Can you tell us why you replaced the keyboard? What was it doing before the replacement?
完成的
Please tell us which type of iBook you have. G3 or G4, etc.
完成的
Did you replace the keyboard because of a liquid spill on it ?
完成的
添加一条评论
2个答案
已选择的解决方案
Hi! Do you have an Airport installed in this machine? The reason I'm asking is that I've often found that if the metal Airport antenna plug is left loose and dangling, and the memory shield is not installed, it can short out the computer by touching the memory or other components on the logic board. Probably an unlikely scenario in your case, but something to look out for.
I would also turn the computer upside down and shake it lightly, and see if you hear loose screws. Loose screws bouncing around inside the case can also short out the board. I've been sold many a "freezing" iBook only to discover the laptop was fine, but that there were loose screws inside causing it to freeze occasionally.
这个答案有帮助吗?
得分 0
添加一条评论
Try running the computer without the keyboard installed, and see if it boots up. The only things you have the potential to mess up by changing the keyboard, are the keyboard, the RAM, and The airport card. If you want, try re-seating the RAM
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
vidaloca828 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 916
