跳转到主内容
本页面收录大多数 iPod 设备的完整拆卸和安装指南,包括 iPod original,mini,shuffle,nano,classic 和 touch。
How can I remove something from my earphone jack?
Making this simple, I broke my headphone adapter in the earjack, how can I remove it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 49
49条评论
Mt twist on the "something suck in my ipad eaphoe jack" is my "something" is one of those silicone beads that come in little packet in your luggage to absorb humidity. The pack broke open and voila' one of the beads found it's way into my earphone jack. Unfortunately, I discovered it when I tried to push in my headphone plug a couple times so I've lodged the bead down pretty hard. The genius bar guys couldn't get it out at Apple and I've found no glue that will stick to silicone. I'm ready to try the drill thing, wondering if there are any other simple ideas or guide for the drill idea.
完成的
I have the EXACT same problem, dont know what to do.
完成的
Same issue with mine... looking for something to poke it with >_<`'
完成的
Use a straw like the ones you get in the square cartons of juice that's how I got mine out.on the downside the port is a bit messed up but my speakers work again
完成的
To remove crushed paper or lint... use a paperclip or sharp end of a safety pin...
完成的
显示更多的44条评论
添加一条评论
18个答案
已选择的解决方案
There is a tool we made that was on Kickstarter called the GripStick. It is made specifically for removing a broken headphone plug from any standard audio jack. It's available now.
https://www.youtube.com/watch?v=Ii5OKvtN...
http://nightek.com/
https://www.kickstarter.com/projects/nig...
Cheers!
这个答案有帮助吗?
得分 9
6条评论:
We have a few and they work!
完成的
I bought one!!
完成的
Yep, and the tool is garbage too. Tried it on 3 different iPads with headphones broken off in it and the tool winded up breaking. Followed the exact video on the store page.
完成的
If you twist it you can snap it! We managed to break one the first time we used it. Once we pressed and pulled it worked just fine. Of the three we still have we use them almost every day.
完成的
I purchased two back in 2015. I use them frequently but only have success about 25% of the time. Still looking for something better.
完成的
显示更多的1条评论
添加一条评论
此回答最初是针对另一个问题
I believe everything you have mentioned is viable. It Just comes down to preference. Please see this post for some more help.
这个答案有帮助吗?
得分 5
3条评论:
Thanks for the help... do you know if it's possible to remove the logic board on this generation iMac?
完成的
Yes the logic board can be remove from this model of iMac. The gist of your instructions to do so are here: iMac Intel 27" EMC 2309 and 2374 Teardown
完成的
Not sure if removing the logic board helps though. The socket has a shield surrounding it.
完成的
添加一条评论
此回答最初是针对另一个问题
The best (an especially glueless) way to do it is actually quite simple and doesn't require any fancy tools. You just get a straw, just a normal plastic drinking straw, and cut in it so it can fit your jack. Then you just push it in the jack so it slides around the broken piece of the plug. Then you turn your device so that the jack is facing the floor, and the plug should slip out. If it doesn't, remove the staw slowly with the jack facing the floor and then take a pair of tweezers and grab the part that has already slipped out and pull it out carefully.It's cheap and fast and worked for me... I unfortunately lost my gold-plating on the jack but I think it's nothing glue can't fix.
这个答案有帮助吗?
得分 5
5条评论:
+ very nice idea :-)
完成的
The straw got stuck in the jack and now I can't listen to anything with headphones...
完成的
That's happened to me so I might give this a try the head phones still work but they are a bit louse and make my iPad keeps pausing videos because Siri keeps coming on
完成的
the straw doesn’t fit, it just folds as soon as i put it in. any other things i could use ?
完成的
A straw with a different diameter @gabbycolquhoun
完成的
添加一条评论
此回答最初是针对另一个问题
My ear bud jack was stuck in the female jack of my iMac. I read all kinds of solutions with glue a straw or drilling. All of which imposed a risk of further damage.
Here is what I did and the tools I used.
RS-232 pin straightener (for us old analog guys)
iFixit Probe and Pick Set
iFixit Flat Needle Nose Pliers
I covered the display and unibody with a heavy towel for protection and Unplugged power
Used pin straightened tool to free the edges of the headphone male jack from the female internal jack
Used the smallest probe to pull the stuck piece forward
Used the needle nose pliers to grab the jack and remove it
Success without any damage to my oh so addicting iMac 27"
As always I used this site to get ideas. Thanks iFixit you are amazing!
Picks for for soldering work, poking, prying, scraping, scratching and o-ring removal.图片
产品
Probe and Pick Set
$6.99
ESD pliers with flat faces图片
产品
$29.99
这个答案有帮助吗?
得分 2
添加一条评论
Although I couldn't get mine out, i do have a way to get your speakers working. I don't know anything about how to do this technique in windows 7 but here it is for windows 8. And these instruction are if you have dell, but i am sure that you will have other sound options over there.
1. Open up control panel by going to your start screen and searching for 'control panel'
2. Once its open, click hardware and sound.
3. Click Dell audio
4. Once it opens, click advanced and then jack information.
5. Then click on the jacks( there will be an icon)
6. Another window will open.
7. Click on line( it will be the first option).
8. Your speaker should be working again!!
这个答案有帮助吗?
得分 1
1条评论:
thank you sooooo much!!! i have been without my sound for almost 2 years until now!!!
完成的
添加一条评论
此回答最初是针对另一个问题
If u have the peice that broke of from the stuck peice u can carefully glue on a extention peice wooded\orange stick or toothpick and the other exposed peice that broke off... Put tiny bit of crazy glue on it and try and be patient as u carefully enter it back in the earjack hole. Wait for it to dry. But don't let go of it. Keeping it centered. Than if u gave it at least 3 mins slowly put it straight out. And call yourself a hero. Lol. U need to have a steady hand and patience with plenty of light. It works.
这个答案有帮助吗?
得分 1
1条评论:
Oh don't forget to turn your device off and unplug it first.
完成的
添加一条评论
Hey guys, my name is Lalith. A silicon bead got stuck and I didn't see it. I pushed my headphone in too much and it got struck really hard. So, this is what I did. I took a key chain connector which was really thin interms of width and straightened it out. I just pushed it real hard into the audio port and the silicon thing just broke, came out. I used vaccum to remove some pieces. So everything came out but there was this metal thingy inside which I thought it was the silicon ball and I was just pushing on it too hard. I didn't know that this metal thing is actually a part of the port itself. So be careful not to push on that metal thing too hard.
Thanks guys.
Peace out.
这个答案有帮助吗?
得分 1
添加一条评论
此回答最初是针对另一个问题
Hii! I had this same problem with my iMac 27in today. I use the end of a Qtip Cotton swab. Cut it. Leaving 0.5in including the cotton. The objective is to use the end tip of the hole of the cotton, not the middle. Since it's tighter and has more strength to pull it out. Push it in further then pull it out. It works wonders :)
这个答案有帮助吗?
得分 1
添加一条评论
此回答最初是针对另一个问题
I used a thin screw not wider than the computer audio port head phone jack opening.
Screw into stuck piece of head jack center alignment where it grips into the plastic surrounding
the center audio wire.
Use needle nose pliers to pull screw out. Easy breeze.
这个答案有帮助吗?
得分 1
添加一条评论
此回答最初是针对另一个问题
Thanks for the tip. I had the same problem and used the drilling solution with a 1.5mm bit.
I snipped the end of a standard biro plastic sheath (the inner bit) and shaved it down to a snug fit in the headphone socket.
After a fair few attempts finally go the drill far enough into the offending article to bite and out it came.
This does require some precision so take care.
这个答案有帮助吗?
得分 0
添加一条评论
This is a solution that involves glue but it worked perfectly for me. Get some quick dry super glue and apply some to the broken end of the headphone plug. Make sure that there is none on the sides because we sons want it to get stuck in there forever! Insert the pluck into the jack, making sure that it's perfectly connected to the broken end that's lodged. Leave that in for 5-10 mins and after that, grab the plug and tug it out. Don't pull too hard or twist. NOTE:DONT USE GORRILLA GLUE. Hopefully that helped!
这个答案有帮助吗?
得分 0
添加一条评论
此回答最初是针对另一个问题
I used bamboo toothpick and put superglue on tip. wait after 10 mnts n pull. It works.
这个答案有帮助吗?
得分 0
添加一条评论
I managed to use a thin metal tool and poke some of my earbud piece out, but that's all
这个答案有帮助吗?
得分 0
1条评论:
actually many small metal tools
完成的
添加一条评论
What are some easy ways that will work in 1 sec ?
这个答案有帮助吗?
得分 0
1条评论:
My son got yogurt in the ear jack of my iPad and it says their are headphones in when there isn't any ideas
完成的
添加一条评论
This is literally VERY annoying... I sympathize.
这个答案有帮助吗?
得分 0
添加一条评论
Toothpick helped for me. Just move it around.
这个答案有帮助吗?
得分 0
添加一条评论
此回答最初是针对另一个问题
So, I got a rock stuck in my audio jack and I can't get it out. I want to try and get it out without having to pay a lot of money or damaging the inside.
这个答案有帮助吗?
得分 0
添加一条评论
此回答最初是针对另一个问题
What worked perfectly for me was something that came to mind when I realized I had no superglue, no straw, no drill bit, and so on.
What I used was a very thin NAIL that is used in conjunction with a hammer. It’s about 1 inch in length and is very thin.
I sat the laptop on its side with the aux plug facing up, centered the nail, GENTLY tapped it with the hammer, and pulled it right out with ease, and without damage.
I believe this is the most effective way to remove the broken aux tip. Literally took me less than a minute once the idea came to mind.
The tip of the nail is thin and sharp, therefore penetrating the broken aux tip with ease and not a lot of force. Tapping it GENTLY with the hammer enough to get the tip of the nail inserted to the broken aux tip is all that’s needed. When the nail sits up on its own, pull it up gently and bam. Done.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jonathan Dy 将永远感激不已
浏览统计数据:
过去 24 小时: 7
过去 7 天: 38
过去 30 天: 149
总计 284,888
