跳转到主内容
加入维修社区 - 创建账户
HP Envy h8-1534 是一款 Windows 7 台式机。它包含内置的 HP 多显示器支持技术,支持同时连接两台显示器,方便用户进行多任务处理。HP Envy h8-1534 于 2013 年 1 月发布。
Black Screen With Cursor
My PC Keeps Going To A Black Screen with a cursor and it makes a beep sound when i click somthing on the keyboard or windows open sound and it keeps doing that at wrong times and i have to always restart my pc and i have a Windows 8 and am 11
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
Hi
There are some possible reasons why it happened,
1. Bad Graphic Card Drivers,
2. Bad / Corrupted OS causing it.
3. Check HDD, sometimes degraded HDD can cause this issues, and corrupting system files.
由完成的 分享
Possible defective ram
由完成的 分享
添加一条评论
2个答案
First, backup all your stuff.
Then from a CMD window run CHKDSK C: /f
Then run SFC /scannow
You may also need to run this DISM.exe /Online /Cleanup-image /Restorehealth
Then reinstall the display driver and any other outdated drivers.
Then search for and download any W10 drivers you need and upgrade to W10. I believe you can still do it for free.
NOTE: if there are no W10 drivers for some of your devices, the W7 MAY work fine.
Since the computer came with W7, I don't think W11 will install because of hardware.
Run the update as an update, not a clean install.
If that doesn't work, you may need to do a clean install to get rid of the old registry.
You can revert back to W8. OR you can use Macrium Reflect Free to image your current system.
Reinstalling the image is painless - just make sure you create a recovery medium (USB stick).
However, If you don't want to or can't run W10, I would load W7 - IMHO, It is way better than W8.
这个答案有帮助吗?
得分 0
添加一条评论
Restart the Graphics Driver
The easy and quick fix for the black screen with cursor issue is to restart the graphics driver. For that, you have to press Win + Ctrl + Shift + B at the same time to restart your graphics driver
Regards,
Will
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
NubyNicoYT 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 13
总计 645
