跳转到主内容
加入维修社区 - 创建账户
Wii 于 2006 年 11 月在北美发布,是任天堂第一款直接支持互联网连接的家用游戏主机,通过 Wii 购物频道 (Wii Shop Channel) 支持在线游戏以及游戏和媒体应用的数字分发。
Problem With Wii? Can Any body Help?
My Wii Turn Off After I Play The Game For 15 - 30 Minutes And when I switch it on again and play the Game Again It Wont Start And Turn Off Again.Then After 30 minutes it work again.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
3个答案
最有帮助的答案
i would say you need to turn it on and look in the back. i would bet your fan is not working. its a easy fix to do your self i have repaired lots with this issue . you may be able to stick a toothpick in there and bump the fan to get it working again. but i would replace it as it is going bad ;)
这个答案有帮助吗?
得分 4
添加一条评论
Sounds like overheating, but when game does not work in like 30 minutes, it may be two things.
1) Game disk if you play games what you get from game stores OR Flash memory if you play downloaded virtual console/wiiware games.[
2) Do you have problems with other games? If not, it can be the optical drive.
If you have warranty left, take it to nintendo to be repaired.
If you don't have warranty, here is a link to an new wii dvd drive:
Wii DVD Drive
Replace a broken or damaged optical drive compatible with a Nintendo Wii game console.图片
产品
Nintendo Wii DVD Drive
$29.99
这个答案有帮助吗?
得分 2
添加一条评论
See if anything is blocking the fans movement. It could be your system overheating. If so, this must be addressed as this is a fire hazard
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Azlan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 22
总计 3,133
