跳转到主内容
加入维修社区 - 创建账户
1.6 或 1.8 GHz 双核处理器,2 GB 或 4 GB SDRAM,64 GB 或 128 GB SSD
Broken logic board header
Hey all,
I have a MacBook Air that's been refusing to charge and I noticed upon tearing it down that the 6 pin header for the I/O board has been ripped off the logic board, or at least that's what it seems. The header can be picked up to reveal 6 equal length pins soldered to the surface of the logic board. If I push down on the header with moderate pressure it completes the circuit and everything works. What are my options here?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
You can use a 60W soldering iron to re-solder the header back to the logic board. Use some good flux and some 60/40 solder wire. It will not be that difficult even if you haven’t had any experience in soldering.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Matthew Veitenheimer 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 7
总计 289
