跳转到主内容
加入维修社区 - 创建账户
Sega Master System 是世嘉的第二代游戏主机,属于第三代游戏机平台。它最初于 1985 年在日本发布时名为 Sega Mark III。1986 年在北美发布、1987 年在欧洲发布,并于 1987 年再次在日本发布时,它被更名为 Sega Master System,并采用了新的设计(Model 1 和 2)。
Button 2 on controller port 1 not working
Hi there! I have a NTSC (USA) Master System and button 2 is not working on controller port 1. I have two original controllers and both work perfectly when connected to controller port 2, but if I connect to port 1, button 2 won’t work. I tried resoldering all 9 pins for controller port 1, but problem persists. Any idea what might be wrong? Thank you!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hello, did you solve your problem?
When you re-soldered, did you check continuity between controller port 1, pin 9 to resistor R6 and there to leg 20 in IC #4.
这个答案有帮助吗?
得分 0
1条评论:
Hi there.
I am having the same issue. Button two not working. Have tried and bought new controllers to rule that out. Continuity between pin 9 on the controller connecter is okay and pin 9 to resister R6 is also okay and leg 20 on the IC4 chip to R6 is fine. I have de-soldered and re-soldered the controller connecter just to ensure a good connection. Could the ic4 chip be dead? I really want to solve this for my master system 2
Thanks
完成的
添加一条评论
添加你的答案
Thiago Fernandes 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 27
总计 897
