跳转到主内容
加入维修社区 - 创建账户
A2116 / 2019 / 3.6 GHz 四核 i3、3.0 GHz 六核 i5 或 3.2 GHz 六核 i7 处理器。发布日期为 2019 年 3 月 19 日。
Having problems upgrading i3 with i7 CPU
Hi,
I have a 2019 21.5” iMac i3 3.6 GHz I3-8100 with 8GB
I first upgraded the HDD to SDD which works perfectly
Next I upgraded the RAM from 8GB to 32GB and it too works perfectly.
Finally I bought a new CPU [Intel Core i7-8700 3.2 GHz] but it didn’t work.
I’ve already tried re-installing my old CPU [Intel Core i3-8100 3.6 Ghz] and that works just fine again.
What was the problem? And which CPU do I have to buy to upgrade my iMac.
Thank you for your attention.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Hi! I have the same issue. When I tried to upgrade the CPU from the same i3 8100 to the same i7 8700 the system won’t turn on. When I came back to the original i3 8100 everything was fine.
Is it possible to upgrade the base model’s CPU to anything?
I read something about micro-code in the iMac’s bios, but the same iMac has the configuration with the same i7 8700 cpu. It must be compatible!
Where’s the catch ?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
SERGIO GIRALDO 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 13
总计 487
