跳转到主内容
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1204 个问题 查看全部
Can I boot this up?
Hey all,
So I have a MacBook from 2009 and I was trying to put the key board back on to the device after a repair, unfortunately the keyboard refused to boot the computer up and when I tried to remove it to see what the problem was the connector on the keyboard came loos and disconnected from the board. In attempt to boot up the computer I located the power pads and booted it up though there and I was like “Oh ok good ill just leave the top case off and ill boot it up that way. After reassembling the computer I set a flathead drive to the pads and it made all the common sounds (hard drive spinning, optical drive doing its thing) and I received no input from the display (i’m using an external monitor as my main screen as the original is cracked). I unplugged it and plugged it back in and tried again. this time nothing happened. But the battery is charging and the light on the charger lights up, so now I'm lost as to how to boot the thing up and get feedback from the display.
Any help is much appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hopefully you have not shorted the board out, It sounds like you got an incomplete insertion of the keyboard cable into the logic board. To help with that use a piece of electrical tape on the cable and pull it into the slot rather than trying to push it in.
To get a spontaneous reboot of your computer, disconnect the battery and mag-safe. Press and hold the power on button for ten seconds. Reconnect the battery, then the mag-safe and it should boot on its own.
这个答案有帮助吗?
得分 1
4条评论:
the connector on the logic board is fine but the one on the keyboard and trapped is missing so therefore I cannot connect the keyboard
完成的
Is it missing or did you cover it up when you put the logic board back in and now trapped under the logic board?
完成的
It's missing. It looks like it was removed forcefully due to a slip-up I had while repairing it.
完成的
So you ripped it off. So what the ,,, you need to replace the keyboard with an intact cable to get it to work.
完成的
添加一条评论
添加你的答案
Jack K 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 47
