跳转到主内容
加入维修社区 - 创建账户
HP Envy 4520 是一款一体式无线打印机和扫描仪,由惠普 (HP) 公司制造。它于 2015 年 8 月发布,可通过产品编号 F0V69A#B1H 进行识别。
Clearing a paper jam
I can’t get hold of enough paper to slowly pull it out. The jam is at the front small roller, not under the paper path drawer. Paper has rolled around the front roller several times and there is about 1/4” of paper sticking out, not enough to pull
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Open the top copier door and glass door at the same time, like you're changing the ink. At the very back, there is a flap with 2 gray slide pulls that you pull toward each other, then pull upward. Your stuck paper debris should be there, clear it out. Hold the 2 slide pulls again and put the flap back where it was. Close lids and the menu should ask if it can continue.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Connie Staats 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 14
总计 990
