跳转到主内容
加入维修社区 - 创建账户
Model number NV370. Stands 27 inches tall and features Shark’s never loses suction technology and swivel steering.
Vacuum won't let me push or pull on carpet.
I was using my Navigator Lift-Away Pro on the carpet and it was working fine then the red light came on and I couldn’t move it. After cleaning I tried it again soon as I put it back on the carpet it did the same thing again it seems the brush stops spinning.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
If your Shark Navigator Lift-Away Pro vacuum’s floor roller no longer spins, see the Shark Navigator Lift-Away Pro Floor Roller is Not Spinning problem page for possible causes and solutions.
这个答案有帮助吗?
得分 0
添加一条评论
Because of such a malfunction, I damaged my carpet.
这个答案有帮助吗?
得分 0
添加一条评论
The red light indicates the brush roller has stopped. Something is caught inside the roller brush. Turn off the vacuum. Remove the object and turn it back on. Green light should turn on. Remember, brush roller needs to be turned on when your vacuuming carpet. If not it will be hard to push.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
drosser333 将永远感激不已
浏览统计数据:
过去 24 小时: 7
过去 7 天: 28
过去 30 天: 112
总计 6,671
