跳转到主内容
加入维修社区 - 创建账户
Asus TUF Gaming FX705G 是一款由华硕于 2018 年制造的游戏笔记本电脑。
Internet icon cannot be enabled?
My Wifi icon cannot be enabled. Internet is available. Please help…..
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Hi,
Check the status of the WLAN adapter in Device Manager.
To get to Device Manager in Win 10, right click on the Windows Start button on the left side of the Taskbar and click on the Device Manager link in the options box that opens.
When in Device Manager, scroll down to Network Adapters and click on the > symbol to the left of the entry to expand the list and then right click on the WLAN entry (should have “Intel” mentioned) and select Properties. Check the status in the General Tab.
If there is a yellow exclamation mark next to the WLAN adapter entry, you will have to update the drivers for the adapter. (right click on entry and select Update drivers) If you cannot access the internet using an Ethernet cable you will have to manually install them or you could try uninstalling the adapter (right click on entry and select Uninstall and follow the prompts). Restart the laptop and Windows should reinstall the WLAN adapter drivers. Check if it now works.
If there is a red cross next to the WLAN entry, right click on the entry and click on Enable. Check if it now works.
If there is no WLAN adapter entry in Device Manager, check if there is an Other Devices listing in Device Manager and see if it is listed there. Also click on View > show hidden devices to see if it appears.
If there is no WLAN entry at all in Device Manager, not quite sure in your laptop but check in BIOS > Advanced Mode > Security > I/O Interface Security to see if there is a WLAN entry and if so, if it is enabled. If disabled, enable the setting, save the changes and restart the laptop.
To access BIOS press F2 during boot i.e. time between starting the laptop and Windows start screen appears, usually when the Asus logo is on the screen
这个答案有帮助吗?
得分 0
3条评论:
The device is working properly. But cannot turn “on” network. Help…
由完成的
由完成的
@Alan Hui ,
Try the following:
Go to Control Panel > Troubleshooting > Network and Internet > Internet Connections and follow the prompts
To get to Control Panel in Win10 type Control Panel in the Win search box on the left side of the Taskbar.
由完成的
添加一条评论
When Asus laptop wifi icon is missing on the laptop. you need to make the following changes into the laptop .
  1. Let's turn on the Wifi on the asus laptop by using the network settings.
  2. Go to the network settings, here you need to update the username and password for your WIFI.
  3. Sometimes, Asus laptop won't connect to wifi because of the password issues, so you need to remove the current account. now re-add Asus laptop on your phone.
  4. If Asus laptop does not connect to the wireless network and keeps showing the Firmware issue. you should disconnect the laptop. now configure the Asus laptop. it should be working fine on your device now.
So these are the steps to fix the Asus laptop does not connect to the wifi problem. in case, if you need more help, you need to visit askprob blogs. there you will find the complete guide.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Alan Hui 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 21
总计 1,650
