跳转到主内容
加入维修社区 - 创建账户
HP ZBook 15u G3 是一款 2016 年发布的笔记本电脑。许多用户可能需要扩展其存储空间、更换某些组件以及进行维护。
Plugged in not charging
i have tried 3 chargers now, but it stil won’t charge.
what can be the problem here?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
Hi @sidern ,
Does the battery light on the side of the laptop turn on when you connect the charger to the laptop, you didn't say?
If so what colour is it?
由完成的
How do you know it’s not charging? Does it turn on/boot up normally?
由完成的
yes it turns on and boot into windows, battery icon chows 0% plugged in, not charging.
由完成的
添加一条评论
1个答案
已选择的解决方案
hi @sidern,
You may have a faulty battery.
Create a Win 10 battery report to check on the condition of the battery.
If it is determined that the battery needs replacing here’s the maintenance and service guide for the laptop.
Go to p.40 to view the necessary pre-requisite steps and then the procedure to remove/replace the battery.
Also at the top of p.40 you will find the part number for the battery. If you search online using the part number only in the search term of your browser, you’ll get results for suppliers of the battery
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
tor_arne_ovrum 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 33
总计 6,836
