跳转到主内容
加入维修社区 - 创建账户
Guides for the LTE version of the iPad Mini 2. Announced October 22nd and released November 12th, 2013. The iPad mini 2, originally known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
Replaced my screen digitizer.
I replaced my digitizer and anytime I press on the screen, I can see the LCD liquid getting squished even with the lightest taps. I made sure that there is nothing in the way under the LCD which is all clear. Why does this happen?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Usually it comes to one or more of the following:
  • The 4 screws that hold the display down at the corners are not put in.
  • The battery has started to expand putting pressure behind the screen.
  • The housing of the iPad is bent in a way that does not let the digitizer sit flat without touching the screen.
  • Also there is usually a protective film that needs to be peeled off behind the digitizer which can also cause this problem as it adds thickness to the screen.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Imatrueguy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 14
总计 151
