跳转到主内容
加入维修社区 - 创建账户
具备 12 小时播放续航的户外蓝牙音箱。获 IPx7 级防水认证。防震。内置 5200mAh 移动电源。
Requires odd trick to unplug
Brv-x has power on issue. Turns on fine and works normal when plugged in but dies when unplugged. Herege's the odd part, if while on and plugged in I can use my adjustable charger to reduce the incoming voltage down from 12v to 7.5v, the device continues to work and can then be unplugged. It cannot be turned on without 12v external power ( 7.5v won't turn it on, nor will just battery power) and it can't be unplugged while receiving 12v external power or it instantly cuts off altogether( 7.5vexternal is required to unplug from wall, only way to make it work…) thanks for any help you can give.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi,
The battery is failing and needs to be replaced.
Here’s a link to the ifixit Braven BRV-X 电池更换 guide which may help.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Theon Lyme 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 19
总计 421
