跳转到主内容
加入维修社区 - 创建账户
Epson 打印机的维修与拆解指南。该公司成立于 1942 年,最初名为大和工业有限公司 (Daiwa Kogyo, Ltd.),于 1959 年与其他公司合并组建了諏访精工舍 (Suwa Seikosha Co., Ltd.)。
error light paper blinking
Hi,
My epson printer L3110 having light paper blinking but already check all is good. No paper jammed or any object inside the paper slot. I check with system show : MEMORY CARD IS LOADING ERROR
so what should I do to get the printer is normal? And what the solution to solve this error.
This is new printer as i buy last month.
Hope can help and run as normal.
thank you
Rafi Haron
回答此问题 我也有这个问题
这是一个好问题吗?
得分 7
添加一条评论
6个答案
最有帮助的答案
Knowing the model number is always helpful.
This can sometimes revive epson printers that are being difficult…
https://epson.com/support/updating-your-...
这个答案有帮助吗?
得分 1
添加一条评论
The way to solve this problem is quite easy if you want to follow the procedure I explained like this, open explores -> this PC -> Manage -> device manager -> print -> update driver.
After the driver is updated, if it doesn't work, just uninstall the driver then download it again by clicking via the link below:
download driver epson l3110
这个答案有帮助吗?
得分 1
添加一条评论
i know ,that probel will make you job disturb, i want to give suggestion you can find theright driver for your printer driver. I know but it is for model epson l1110 may be next time i will find good driver source for your epson l3110
这个答案有帮助吗?
得分 0
添加一条评论
Rafiharon bom dia,
deve ser algum sensor q esta com problema em sua impressora, e por isso acusa o erro de papel, verifique tambem se pode ser a mola do sensor de papel, pode ter escapado.
这个答案有帮助吗?
得分 0
添加一条评论
katika epson l3110 taa ya ink na taa ya paper zinawaka pamoja nini suluhisho
这个答案有帮助吗?
得分 0
添加一条评论
Boliye is ka solution
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Rafiharon 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 10
过去 30 天: 23
总计 4,478
