跳转到主内容
2015年十一月,华为发布了Mate 8。Mate8搭载了安卓6.0系统,具有6英寸的屏幕。有32GB以及64GB的内存,3GB的RAM以及4GB的RAM两个版本,一个16MP的后置摄像头和8MP的前置摄像头,一个4000毫安时的草鸡大的电池
15 个问题 查看全部
Where is the smart cover sensor on the phone?
Hi, I’ve replaced the USB charging port successfully and everything works fine, except the smart cover. Seems its magnet isn’t recognized anymore and the screen doesn’t lock on closing the cover. Any idea where the sensor recognizing the magnet is? Might it be on the USB charging port board I replaced?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
What phone do you have?
完成的
Sorry, my bad. I switched his comment to a question and must have missed categorizing it. If I remember correctly it was with the Huawei Mate 8.
If necessary THBE can add a photo of the smart cover for detailed information.
完成的
添加一条评论
1个答案
Hi THBE,
not sure where the magnet on the smart cover sits. You might want to check the position of the magnet (using a paper clip maybe) and then look for any sort of sensor in the phone at the respective position.
I can imagine that maybe the small extension of the loudspeaker unit (bottom left next to the USB charging board) that extends to the side might carry an extra sensor.
There are also two magnets on the left rear edge of the phone assembly when opened (right edge when looking at it from the back with the back cover off), but that would be inverse to how a smart cover usually works.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
THBE 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 528
