Why is my muffler glowing red hot starts right up and seems to run
Meffler gets red hot and glow when full throttle starts fine does not boggle but does seem week
The reason the muffler is glowing red is because the exhaust temperature is off the chart.
This (highly likely) means that the ignition timing is out, or the fuel mixture is too lean. One possibility on small engines that run a flywheel magneto is that the keyway/key may have damaged itself or sheared off, allowing the timing to go out. Or, the carburetor is gummed up, not allowing full flow of fuel.
What does this mean? Well aside from the engine going outside of it's safe operating temperature (wearing out components faster), it can also lead to detonation, which is where the fuel is igniting before the end of the compression stroke. This can result in breaking the connecting rod and destroying the engine.
I would not use it without making adjustments.
这个答案有帮助吗?
Sounds like its running lean at the high end. Double check the fuel/oil mixture is correct. Also the high rpm has a mixture adjustment on the carb. Best to have someone that has adjusted those before to get it set correctly.
这个答案有帮助吗?
Time to get rid of the Ford and buy a Chevy
I have just experienced this problem and the results were devastating. The muffler is bad replace it right away or you will be dealing what I am dealing with. The red hot muffler caused the engine to over heat, it blew the oil right out causing a whole engine rebuild! And getting parts for this thing is ridiculously expensive and that's if you can find them. The muffler is expensive I paid $640 for mine. Before you can get it replaced your engine will burn oil bad. Keep a close eye on the oil or you will be in the same boat as me.
这个答案有帮助吗?
It can be caused by a clogged catalytic converter. It can also be caused by timing being off
这个答案有帮助吗?
过去的24小时: 33
过去的7天: 265
过去的30天: 1,209
总计 14,993
