跳转到主内容
The Sony Ericsson Xperia X10 was the first Sony Ericsson smartphone to utilize the Android operating system.
12 个问题 查看全部
How do You fix or replace the Charging Port
I have a Sony Ericsson Xperia X10A and the past week i have noticed a loose charging port. Today the phone will not charge at all. I have changed batteries and chargers, but still not charging. I did some research online and have found that these phone are known for loose charging ports. I have order a new charging port but it doesn't have intrustions with it. I love my phone and it's not even a year old, so i just want to fix it not replace it. Can you help me?
Thanks
Tracy
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Tracy Richards, just make sure that if your phone is still covered under warranty, use it. Don't tear it apart unless you are not covered...
完成的
添加一条评论
1个答案
已选择的解决方案
Tracy Richards, the service manual is available right here. It will show you how to replace things that are replaceable. Hope this helps, good luck.
这个答案有帮助吗?
得分 1
19条评论:
Thank you. And no my phone isn't under warranty. Thank you for your help.
完成的
Thank you for accepting my answer. I hope things will work out for your phone.
完成的
hey do you mined sending it to me pls at grownupgear@yahoo.com pls
完成的
Sorry, I don't do emails because of size etc. you should download it here :-) good luck.
完成的
Hi oldturkey0
Can you set the sharing so i can view the manual
Thanks in advance
J
完成的
显示更多的14条评论
添加一条评论
添加你的答案
Tracy Richards 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 11,542
