跳转到主内容
加入维修社区 - 创建账户
适用于现已停产的 Minolta 产品线中胶片相机与数码相机的维修指南。
MINOLTA SRT-200 Shutter button issue
PLEASE HELP ME. I have a shutter button issue with my Minolta SRT-200. I recorded a video to explain the issue. Thank you in advance : https://youtu.be/uUvUTI81yEY
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
6条评论
So the spring is not mounted to the lever. You're lucky!
由完成的
@danj So, is there something I can do? Do I need to mount it? How does one do that?
由完成的
Use a dental pick to drag the hooked end over the lever. Be careful as if you slip the spring can jump off the post to the winds, which is what I had thought you had encountered before.
由完成的
@danj hi dan, i added an updated picture? Did I do this right?!
由完成的
Is it working correctly now?
由完成的
显示更多的1条评论
添加一条评论
1个答案
已选择的解决方案
When you cleaned your system you snagged a small spring which holds the stop lever under tension. Looking at the SRT101 service manual which uses the exact same mechanism the spring 3067 is what you lost referencing this guide page17 Minolta SRT101 Service Manual
这个答案有帮助吗?
得分 2
3条评论:
Hi Dan,
Does that mean I cannot fix it myself? I Don't believe I broke anything as I was very delicate. Is there anything I can do?
由完成的
The spring is as thin as a hair! And it tends to pop off. Its steel, so a magnet will grab it but as it's so small it can get caught in the rug or cleaning cloth.
You'll need to get a new one somehow.
由完成的
I added a picture, i removed the light meter battery holder, can you see it @danj ?
由完成的
添加一条评论
添加你的答案
Emeric Seguin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 12
过去 30 天: 20
总计 1,205
