跳转到主内容
加入维修社区 - 创建账户
华为 Mate 7(也称为华为 Ascend Mate 7)是华为公司生产的一款 Android 智能手机,于 2014 年 10 月发布。包含型号 MT7-TL00、MT7-L09、MT7-TL10、MT7-CL00。
stuck in reboot loop
Cant turn on or off, it is stuck in a reboot loop, suspecting possible drainage,
been put inside the toilet for a while
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Yes, water damage usually comes with a reboot loop. Don’t give up.
Firstly, if the motherboard is OK, check whether the Flex Cable is the cause as it may be corrupted in this circumstance. Replace it if it’s damaged.
Since the effects of water damage on phone is long lasting, you’d better consider transferring important data out of the memory to another devices.
If you fail to access its memory, then you will need some special tools to recover files from your android. You can find many such tools on internet.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Caspian 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 19
总计 695
