跳转到主内容
加入维修社区 - 创建账户
第二代 Suzuki Vitara 比第一代稍大。在北美市场,它曾以 Chevrolet Tracker 的名称贴牌销售。
check engine light does not burn
My suzuki grand vitara failed an emissions control test because the check engine light would not turn on for test. I was told to reset the control system by disconnecting the battery for a few seconds. Ran it for while, light functioned for a while then went out again. Bulb is fine. What else could be the problem.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
最有帮助的答案
Hi @smr2cmpn ,
Does the check engine light come on when you turn the ignition key to the On position?
Various warning lights including the check engine light, on the instrument panel will light up when the ignition key is in this position and all should go out very shortly after the engine has started.
If the check engine light stays on are there any other lights staying on as well?
The check engine light should not stay on after the engine has started or come on once the engine has started unless there is a problem with the engine.
Have you had the car’s OBDII port scanned for any codes? If there are any and the check engine light has been operating intermittently the codes should help you know what the problem may be.
If you are in the USA, AutoZone will check for the codes for free apparently.
What is the model year of the vehicle?
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Calvin E Williams 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 14
过去 30 天: 45
总计 1,693
