跳转到主内容
Jeans are comfortable, everyday pants usually made from tough yet comfortable denim.
4 个问题 查看全部
How to repair holes in the crotch of my Tenpenny Pants
My Patagonia Tenpenny Pants have developed some holes/rips in the crotch. Most of my trousers do this eventually. Is there a repair I can make to get more life out of them? They're made of cotton/polyester
Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Chub rub! Also my primary failure point for all Pataguchi pants. There MUST be an easier repair than just loosing weight.
完成的
添加一条评论
1个答案
已选择的解决方案
You can do an iron on patch:
Installing an Iron-on Patch
The zig-zag patch requires a sewing machine:
Zig-zag Patch
Patagonia Jeans图片
指南
Zig-zag Patch
难度:
简单
10 - 15 minutes
Patagonia Jeans Iron-on Patch图片
指南
难度:
简单
5 - 10 minutes
这个答案有帮助吗?
得分 3
3条评论:
I saw those,but I wasn't sure if they would work on a non-flat bit of the clothing (the crotch is a kind of saddle shop on most clothes)
完成的
I've done it on elbows. I put a patch on both sides and sometimes hand stitch the corners down so they don't curl up. eBay has patches but most come in from China (I've had a set of denim patches ordered now for a couple of weeks but the shipping now says VOID). You can probably find them in the states just at a higher price.
完成的
Clothing starts out as a flat piece of fabric and has curved seams to fit your shape. You can smooth down the area to where it’s flat and add a patch. You’ll follow the curved seam to keep the shape. If you are hand sewing use a back stitch which is strong and won’t loosen. For a source of patches try your local fabric stores. You don’t have to use a precut patch, you can cut your own from new fabric or my favorite, old pants ( which are already softened from wear). Denim will fray on a cut edge so just put the patch on the inside if that’s not what you like. or enjoy an edgy look.
I love that ifixit supports repair solutions!
完成的
添加一条评论
添加你的答案
Matt Freake 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 9
过去 30 天: 29
总计 2,207
