跳转到主内容
Zig-zag Patch
你所需要的
  1. Zig-zag Patch, Zig-zag Patch: 步骤 1 中的图像 1,3 Zig-zag Patch, Zig-zag Patch: 步骤 1 中的图像 2,3 Zig-zag Patch, Zig-zag Patch: 步骤 1 中的图像 3,3
    • Examine the damage. Clip any long, loose threads, and remove any debris from the hole.
    • Measure the length and width of the hole.
    • In our case it looks like 2" by 1".
  2. Zig-zag Patch: 步骤 2 中的图像 1,3 Zig-zag Patch: 步骤 2 中的图像 2,3 Zig-zag Patch: 步骤 2 中的图像 3,3
    • Grab a scrap of denim or other heavy-weight fabric and mark your measurements plus one inch in each direction.
    • In our case it will be 3" by 2".
    • Cut the scrap into a rectangle the dimensions of your new measurements.
  3. Zig-zag Patch: 步骤 3 中的图像 1,2 Zig-zag Patch: 步骤 3 中的图像 2,2
    • Insert the rectangle of fabric into the jean leg and position it under the hole.
    • Be sure that you put the rectangle of fabric in the pant leg and not behind it—you only want to work on one layer of fabric.
  4. Zig-zag Patch: 步骤 4 中的图像 1,3 Zig-zag Patch: 步骤 4 中的图像 2,3 Zig-zag Patch: 步骤 4 中的图像 3,3
    • Thread your sewing machine with your desired thread color.
    • Slide the pant leg onto the arm of the sewing machine.
    • You may need to remove the sewing machine table for the pant leg to fit over the arm.
    • Be sure that the pant leg is around the arm of the sewing machine. If both layers are stacked on one another, you will sew the pant leg shut.
  5. Zig-zag Patch: 步骤 5 中的图像 1,3 Zig-zag Patch: 步骤 5 中的图像 2,3 Zig-zag Patch: 步骤 5 中的图像 3,3
    • Check that the rectangle of fabric is still laying flat, centered beneath the hole.
    • Lower the pressor foot.
    • Sew a straight line over the hole going about five stitches past the damage.
  6. Zig-zag Patch: 步骤 6 中的图像 1,3 Zig-zag Patch: 步骤 6 中的图像 2,3 Zig-zag Patch: 步骤 6 中的图像 3,3
    • Lift the pressor foot.
    • Rotate the jean leg a few degrees toward the center of the hole.
    • Engage the backstitch function on your sewing machine, and sew a straight line back over the hole, going about five stitches beyond the damage.
  7. Zig-zag Patch: 步骤 7 中的图像 1,3 Zig-zag Patch: 步骤 7 中的图像 2,3 Zig-zag Patch: 步骤 7 中的图像 3,3
    • Repeat steps five and six, continuing to rotate and sew lines of stitching back and forth until you cover the entire hole.
  8. Zig-zag Patch: 步骤 8 中的图像 1,2 Zig-zag Patch: 步骤 8 中的图像 2,2
    • When you are satisfied with your stitching, backstitch two or three stitches.
    • Lift the needle and pressor foot.
    • Slide the jean leg off of the sewing machine.
  9. Zig-zag Patch: 步骤 9 中的图像 1,2 Zig-zag Patch: 步骤 9 中的图像 2,2
    • Clip any dangling threads and admire your work.
  10. Zig-zag Patch: 步骤 10 中的图像 1,3 Zig-zag Patch: 步骤 10 中的图像 2,3 Zig-zag Patch: 步骤 10 中的图像 3,3
    • Still not satisfied? Alrighty, let's add some decorative stitching the other way.
    • This is completely optional. If you are happy with your work, you can stop here.
    • Slide the pant leg back onto the arm of the sewing machine, making sure that the leg goes around the arm.
  11. Zig-zag Patch: 步骤 11 中的图像 1,2 Zig-zag Patch: 步骤 11 中的图像 2,2
    • Carefully rotate the jean leg 90 degrees.
    • Be sure that there is only one layer of fabric (plus the rectangle) between the sewing machine and the needle, or else you will sew the pant leg shut.
  12. Zig-zag Patch: 步骤 12 中的图像 1,2 Zig-zag Patch: 步骤 12 中的图像 2,2
    • Sew a straight line of stitching over the damaged area.
  13. Zig-zag Patch: 步骤 13 中的图像 1,3 Zig-zag Patch: 步骤 13 中的图像 2,3 Zig-zag Patch: 步骤 13 中的图像 3,3
    • Just like before, at the end of each line of stitching, lift the pressor foot, rotate the jeans a few degrees, and sew another line of stitching.
    • When you are happy with the way that the stitching looks, backstitch two or three stitches.
  14. Zig-zag Patch: 步骤 14 中的图像 1,2 Zig-zag Patch: 步骤 14 中的图像 2,2
    • Lift the pressor foot and needle.
    • Slide the pant leg off the arm of the sewing machine.
  15. Zig-zag Patch: 步骤 15 中的图像 1,2 Zig-zag Patch: 步骤 15 中的图像 2,2
    • Clip any dangling threads.
结论
Ta-da! Nice work.
8等其他人完成本指南。
Brittany McCrigler
于03/05/12注册
90,547 声望
创作了142篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,829篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 19
过去 7 天: 90
过去 30 天: 355
总计 36,679
