跳转到主内容
加入维修社区 - 创建账户
A1297 一体成型机身型号:2009 年初、2009 年中、2010 年中、2011 年初及 2011 年末
Metallic taste when using track pad
When I was swiping my fingers across the track pad i could taste a metallic substance from the computer this my second macbook pro and the first one had the same results.
Has anyone else had this problem?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
4条评论
This question was migrated from http://www.ifixit.com/Answers.
由完成的 分享
This question was migrated from http://meta.ifixit.com/Answers.
由完成的 分享
I think this question is a ploy to get us all licking our fingers!
由完成的 分享
I have that SAME thing! People think I'm nuts, but it happens when I use my MacBook AND my iphone. I didn't realize that it was with all Apple products for me. So weird. I have had MANY computers and phones, but Apple is the only thing I experience it with.
由完成的 分享
添加一条评论
4个答案
已选择的解决方案
Have your dentist replace your silver amalgam fillings with a composite material. Your metalic taste is most likely being caused by the slight electrical current discharging in your mouth via your fillings. Read up on it here: http://www.drpgilbert.com/metallic-taste...
这个答案有帮助吗?
得分 20
5条评论:
Didn't know this was possible. +
由完成的 分享
I was thinking similar lines re small current/electrolyte problem but more localised, it's a good read.
由完成的 分享
+ Hah! I had no idea this was possible. Crazy stuff.
由完成的 分享
Did you find the answer to your problem?
由完成的 分享
Early in my life I had a dental laboratory and did crown and bridge work, went to lab school for two years.
由完成的 分享
添加一条评论
I don't think it's normal to experience tasting flavors from simply touching an object.
That said, if you are touching an aluminum case and you lick your fingers afterwards, it's possible that you could be licking up some aluminum dust.
Either way, I wouldn't recommend licking your fingers or your laptop.
这个答案有帮助吗?
得分 5
1条评论:
My dog does that for me ;-}
由完成的 分享
添加一条评论
I would try adding a colloidal minerals supplement in the liquid form to your diet to see if this resolves any mineral deficiencies you may have. Many of the minerals are metals. In chemistry the Theory of Equallibrium tells us that all touching matter exchanges atoms. I would also try washing your hands prior to touching the track pad. Colloidal/Ionized minerals are in the form of salts. Your sweat has salt in it.
Look to see if touching other items brings this sensation. That may help you narrow down the cause of it.
这个答案有帮助吗?
得分 3
3条评论:
that's what I was thinking.. you put it much better than i could.
由完成的 分享
I think if you had elaborated on your thoughts Poly that your words would have been more eloquent than mine. However no one seems to view our thoughts as a viable solution to the problem at hand.
由完成的 分享
ha ha..at hand! get it? ah well no one else will either. ;-P
由完成的 分享
添加一条评论
sometimes, when i move myfingers over the metal part of my laptop, both the unibody and the one before, i feel some ‘stick-slip’. it is gone when i unplug the power. clearly, some voltage comes through.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Michael 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 39
总计 4,049
