跳转到主内容
A clothing iron, also called a flatiron, is a heated surface used to remove wrinkles from fabric.
85 个问题 查看全部
How do I disassemble a Philips GC4910/19 PerfectCare Azur Steam iron
When I use the iron, it intermittently trips the rcd. There is a single screw at the back of the handle behind the cable that I have taken out but there appears to be nothing else to remove to get inside or to get the part out that the screw was securing at its top.
Can anyone help.
Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
'fraid not. It's for an older model that strips down from the front. Tx anyway.
完成的
My iron just stopped heating. It was coincident with descaling but not sure if that means anything. The suggested video was not helpful.
完成的
添加一条评论
2个答案
已选择的解决方案
See if this guide will help you:
Phillips Azure Steam Iron Disassembly
这个答案有帮助吗?
得分 2
添加一条评论
The next thing you need to do is to remove the blue decorative cover that is over the two lower screws at the back of the iron. I am not sure how you do that without breaking at least some of the small tangs that hold it in place, but it’s not anything but decoration so not a huge deal.
After that, the other thing that isn’t intuitive is removing the top bit of the handle. This is held in place by 4 tangs on each side. I did it by a combination of working a flat blade screw driver at the seem between the upper and lower part of the handle and wrapping a pair of pliers with a cloth and squeezing the top part together while pulling it from the lower part of the handle.
q
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Rob FJ 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 16
过去 30 天: 51
总计 1,896
