跳转到主内容
Repair guides and support for your LG TV.
1341 个问题 查看全部
Why does my TV click then shut off if tilted forward or backward?
If I tilt my TV forward or backward it makes a click sound then shuts off and won't come back on unless I either tilt it again or unplug and plug it back in. This really wasn't an issue as long as it wasn't moved HOWEVER a while ago it did this but when I got it turned back on the TV will not respond to the remote or the buttons on the front of the TV. There is a good picture AND sound although it's very low but I cannot change the channel, turn volume up or down, bring up the menu, turn it on or off, or ANYTHING else. The remote sensor light on the front of the TV blinks when I press a button on the remote so I know it's trying to communicate but can't. Is it a bad capacitor on the power board? Or something else? Please help. It was given to me and it's got a great picture so I would really like find out what it is. It's an LG 50PX2DC-UD Plasma (50 inch I think).
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
@aalexx918 since it does that with movement this is not typical of any component having failed. This sounds more like loose connections or loose boards. It is time to remove the back cover and check all wiring etc. on the boards. Post some good pictures of your boards, wiring etc. That way we can see what you see.
在已经存在的问题里加入图片
这个答案有帮助吗?
得分 0
1条评论:
So do you think I may have two or more things happening at the same time? I mean is the fact the TV won't respond to the remote or front panel buttons have anything to do with the possible loose power etc? Or is it a separate issue? Thank you for your help btw.
完成的
添加一条评论
I have this proble too, its hard to Sell this tv tobsecond hand, Lot of people talking about this ptoblem, never buy LG, buy Sony, have great CPU 8core, but lot of heatsinks , I use Sony TV in work as monitor 4k60p 4:4:4 , he ran 24/7 never restart or any issue. Its coster than LG but is TV, easy sell as old TV still work. I have LG in home and for compare LG is 80286 and SONY is core i9 serious no lag TV.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Amy Alex 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 12
总计 250
