跳转到主内容
Repair guides and support for LED, LCD, HD and other Vizio TVs.
931 个问题 查看全部
The screen cracked and displays rainbow lines
Hello ifixit,
I just got my neighbors old Vizo 65’ TV. (D65x-G4) It worked fine except for the HDMI port sometimes stopped displaying the input on the screen. After messing wit it for a bit it would work fine, this was b4 the screen was hit or banged and cracked, but you couldn’t tell till it was plugged in. When it was plugged in the area around the crack was covered with rainbow colored lines. Now it’s mostly back except for the colored lines. There is only partially part of the screen left anymore now that isn’t black or has colored lines.
I have a Vizo D65x-G4 and would like to know what parts I need to fix it. I can’t afford a TV this big or nice right now but can pay for parts if it’s fixable. An instruction guide would be helpful as well, but having the right parts is the most important!
thanks
Michael
(the Jersey Devil)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@fiero2mike this sounds like a broken LCD display. There is no fix for it and the only thing you can do is to replace the display. Here comes the bad part. display panels that size are very difficult to come by and will often times cost you more than a new TV. You can of course try and find a panel. Vizio uses a hodgepodge of parts, so you will have to remove the back cover. You should find a label glued to the panel that will tell you the manufacturer and panel model. Use those numbers to try and find a replacement.
Of course you should always post some ;pictures of what your panel displays so we can see what you see and verify our suspicions
在已经存在的问题里加入图片
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Michael 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 29
总计 2,337
