跳转到主内容
加入维修社区 - 创建账户
Tiny Tot Driver 是一款专为 12 至 36 个月大的儿童设计的玩具。
Where does this part go?!
Hello friends, so my nephews tiny tot driving wheels horn has been jammed into the wheel (halfway, but stuck) it has the toy on repeat when it is pushed hard and is also happening randomly, with movement of the toy.
So i removed the 11 screws for the casing, removed casing, removed the green lever thingy, im pretty sure it was only held in with one screw.
I was called for help so i had to put the toy down for a while.
When i came back i found a piece that i did not notice.
A little white piece of plastic with a screw hole on one end, a metal clip with 4 prongs on the other & some H shaped leg/brace?
I have looked all over this toy to try find its place but i am STUMPED!
So.
I am now thinking it was held by the same screw that I removed from the green lever.
Perhaps it was under the lever and i didnt see it? And its purpose is to hold the black and red wires in place/ out of the way..?
( edit )
I am pretty sure it belongs here, as in photo 4.
Any help will be much appreciated!
Also going to try unstick the horn button now.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Did you figure this out? I don’t know where it goes either
由完成的
添加一条评论
2个答案
最有帮助的答案
This almost looks like the piece that goes behind the red wheel to make it turn. Or to move the clown from button to button
这个答案有帮助吗?
得分 1
1条评论:
The piece does attach with the black back cover to the left of the green clamp holder piece which hold the wheel mechanism in place. If I figure out how to attach a photo I will.
由完成的
添加一条评论
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Dylan Vetrone 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 22
总计 706
