跳转到主内容
加入维修社区 - 创建账户
Repair guides and support for your Toshiba TV.
Backlight is not turning on
Hello,
I have a Toshiba 50L711U18, the backlight is not turning on. Tried using a flashlight and I can see an image. My phone also tries to connect to the chromecast on it as well. These two things are telling me that the T-con board and the main board are most likely working properly. I opened up the front of the display to get at the backlights. When testing them I noticed that a few of them are a dark blue, almost purple color. I read that they might be on their way out, could these few bad LEDs stop the rest of the backlight array from turning on?
I left the TV unplugged overnight, when I plugged it in again the backlights did turn on for 10-15 seconds then shut off and flashed a 12 red light code. I also got a 5 flash code once but it hasn’t returned, the 12 is consistent. I plan on pulling the display off again and rechecking the LEDs, any other troubleshooting help would be much appreciated. I will post my voltages in an attachment.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Tyler Saboe “I read that they might be on their way out, could these few bad LEDs stop the rest of the backlight array from turning on”, absolutely! Since your backlight comes on for a few seconds and since you have a positive flashlight test, this sounds like failed backlight strips. Replace those strips since the LED’s have delaminated. Replacing the strips should fix this issue.
这个答案有帮助吗?
得分 0
3条评论:
Thank you for your response! I cant seem to find any backlight strips but I will keep looking, have you had any success with replacing single LEDs? I have been looking on Digikey and Mouser for SMD LED's and there are a ton of styles. I will have to pop the diffuser lens off and take a measurement of the LED, any other suggestions for the options, current, color?
完成的
It's a PITA to replace single LED's but it should be possible (depends on the strips). Do a search for the backlight strips based on the panel number vs. Toshiba model number.
完成的
Well I ended up getting it fixed, one of the strips connectors lost connection at the solder joint. Touched the connection up and it's stayed on. Thank you for your help.
完成的
添加一条评论
添加你的答案
Tyler Saboe 将永远感激不已
浏览统计数据:
过去 24 小时: 11
过去 7 天: 46
过去 30 天: 184
总计 17,246
