跳转到主内容
加入维修社区 - 创建账户
于2015年十月26日上市的第四代Surface Pro平板电脑。
Problem with new battery
Hello,
I put a new battery in a SP4. While plugged in, the SP4 will turn on, boot, run fine. It shows 16% battery, never more, never less. If I unplug from charger, the surface turns off instantly and does not turn back on until plugged back in. Can someone guide me in what to do here?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
@focusedtech either a bad battery or issues with your charging circuitry. Replace the battery with your old one and see if that behavior is now different. If it is identical it’s your circuitry , if it has changed replace the battery once more with a different one. Of course always double check your work for properly seated cables, connections etc.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Brian Kosarko 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 105
