跳转到主内容
加入维修社区 - 创建账户
无线运动耳机,Backbeat Fit 的后续机型
Headphones not charging - possible error code?
When connected to power, the device flashes red light 15 times and then doesn’t charge. If i depress the power button once during the flash sequence, the red light goes steady and the device charges normally.
Is the 15 flashes an error code? It’s not mentioned anywhere by Plantronics.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Does it always consistently flash 15 times? If not, sounds to me like you have a borked USB cable.
I've also had an issue in the past where the light went solid red and didn't charge. I figured out that the cable between the ears was damaged and had to order a new headset
这个答案有帮助吗?
得分 0
1条评论:
how did you figure that out?
由完成的
添加一条评论
添加你的答案
Henry Collingridge 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 18
总计 583
