跳转到主内容
Model A1285 / 8 or 16 GB capacity
206 个问题 查看全部
Can I still get music off my iPod if--
I was wondering if I can still get the music off my iPod. All that's left of the iPod is the logic board and battery. I've had it plugged into my computer but nothing has came up. Someone told me I probably have to reconnect the display and click wheel for it to work. I took it apart to replace the battery and accidentally tore the ribbon that connects to the click wheel so idk.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Jeremy Floyd you will need the click wheel. You can most likely disassemble everything outside the case to just get it to start up and be recognized if there is no other damage on it.
这个答案有帮助吗?
得分 0
2条评论:
When I plug up another iPod it starts right up without me using the click wheel or does the click wheel automatically send a signal through?
完成的
It is possible that your iPod's firmware is checking for things that work etc. If it does not connect you know you have other issues with your logic board.
完成的
添加一条评论
添加你的答案
Jeremy Floyd 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 12
总计 41
