Black Screen after it fell
MySamsung Galaxy A70 has a black screen the phone works I can hear it when someone calls or when I restart it but the screen is black any help full suggestions
Ik this is from a while ago but just in case anyone else is having this problem, i had this exact problem but when doing a soft reboot the screen became white and pixelated, like an old school tv. I massaged the back of the phone and that seemed to reconnect whatever wire came loose and made the screen work again.
这个答案有帮助吗?
Thanks dude, this massaging trick fixed it for me :)
Zweber Steyn since this happened after your phone fell and you already tried a restart, it stands to reason that this is a broken display. Of course, you always want to check for loose cables etc. but be prepared that this may need a new display. Here is how to do it and displays are available at places like this and many more.
这个答案有帮助吗?
i actually got this problem and knew it was a loose cable because my screen was replced so i opened it and found only 2 screws the other were stolen so i disconnected the battery grabbed flat surface screw driver and placed it between the plast layer cover already removed then i clicked on the battery to lower card and it got plugged in and now my screen works just fine.
这个答案有帮助吗?
过去 24 小时: 5
过去 7 天: 26
过去 30 天: 130
总计 12,514
7条评论
Yes I can hear alarm sound
由 Pavithra Pachu 完成的
All r working well but in a corner black and parpel sport in the screen
由 hafiz.morshed 完成的
It’s makes a little sound when I charge it but it won’t turn on what can I do pls someone help me
由 Adam Lasri 完成的
@Adam Lasri anything happened to it? what have you checked?
由 oldturkey03 完成的
@oldturkey03 it fell then the screen went black but you can hear it and everything so what dose it mean
由 Adam Lasri 完成的
显示更多的2条评论
