跳转到主内容
型号A1288,闪存容量:8、16及32GB
Why won't my home screen come back up?
2 days ago I was given my neighbors ipod touch. He had some data and apps i didnt want on it so i pressed the button that said delete all settings and data. Now it will turn on only to go to an apple that has a face in it, then it flashes white and does it again. Please help.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
14条评论
have you tried to restore it under itunes? Is it being recognized when you plug it in? Was it jailbroken? What model Touch is it?
完成的
Since it isnt turning on correctly itunes or my computer can't recognize it. Yes it was jailbroken and generation i have no clue
完成的
Do you have a number on the back?
完成的
As in a serial number?
完成的
on the back cover in the middle on the bottom there should be a serial number as well as a model number. It is very small :-)
完成的
显示更多的9条评论
添加一条评论
2个答案
已选择的解决方案
This could be caused by having previously be jailbroken and some of your files may have been deleted. You can try to force restore by following these steps The other thing you can try is to use a program like iReb or TinyUmbrella and kick your iPod out of recovery. Any of the above steps could probably reverse your jailbreak. iReb is available here and TinyUmbrella from here. Leopold suggested DFU mode which is better explained at this site. There is also a video on youtube that might help you. Well, give this a try and see what you get. Good Luck
这个答案有帮助吗?
得分 4
2条评论:
Thanks man i dont know what i wouldve done without you!
完成的
You are very welcome and enjoy your iPod ;-)
完成的
添加一条评论
Have you tried to turn your ipod in DFU Mode? Timing is the Key...
这个答案有帮助吗?
得分 1
1条评论:
DFU, what does that mean?
完成的
添加一条评论
添加你的答案
Adam 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 798
