跳转到主内容
Mid 2006 / Model Number: A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor
My Keyboard and trackpad not working
I recently changed my Macbook keyboard the entire topcase, but it is not working at all. I can turn on the machine using the power button on the keyboard and cannot use the keyboard.
Please advise.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 7
2条评论
I have the same problem. Was the issue resolved?
完成的
suddenly my macbook A1181 does not working keyboard and touchpad,what is the solution?
完成的
添加一条评论
8个答案
已选择的解决方案
I agree, check the plug and verify it's connecting on all pins.
Next, since the power button seems to be working, I would try resetting the PMU. With the power off and while connected to AC, hold the power button in for about 10 seconds, until you hear a tone and see the sleep light flashing. I'm wondering if this might cause it to start working.
There is only one cable from the topcase to the board, so the odd thing is that the power button works, but that the keyboard doesn't. Is this a new topcase, or a used topcase? Have you witnessed this topcase working in another laptop?
I have seen Software Update doing a "keyboard firmware" update when I have attached an older (1.0?) topcase to newer A1181, I assume to update it to the newer (2.0?) topcase firmware. While I'm not convinced that the firmware of the topcase is the issue, since I've never had a problem with any topcase working on any A1181, I would be curious to if by connecting a USB mouse/keyboard to the computer and running Software Update, you might be able to update the topcase firmware, and see what that does.
Again, it's a stretch, but besides the keyboard just being bad, that's all that comes to mind.
这个答案有帮助吗?
得分 8
添加一条评论
I have the same problem. I replaced the BlueTooth board in my MacBook Core Duo, and that required removing almost everything, including the keyboard/trackpad. After I reassembled everything, I was able to turn on the MacBook (a button which is on the keyboard) but now neither the keyboard or the trackpad work.
I opened the machine again, checked the cable, unseated and reseated the connector, and turned the machine back on. It didn't help.
I tried resetting the PRAM by holding the power button down ten seconds while off, until it came on and I heard the tone. That didn't help either.
Neither did resetting the SMC (holding the power button down 5 seconds with the power disconnected and the battery removed).
The only thing left for me to do, it seems, is replace the upper case cable in hopes that it was what failed during the machine maintenance.
UPDATE: I replaced the Upper Case Cable, and now the keyboard and trackpad are back to working status. I suggest if you're having this problem, to try replacing this part. It's cheaper than buying an Apple Bluetooth keyboard.
这个答案有帮助吗?
得分 3
1条评论:
I also have this model, Do you have a part number?
完成的
添加一条评论
Open it back up and check for loose cables.
这个答案有帮助吗?
得分 2
添加一条评论
The cable under the battery warps due to heat/the laptop banging on your hip ON THE BATTERY when you carry it around.
It is a known issue, affects a number of non-unibody MBPs.
这个答案有帮助吗?
得分 2
1条评论:
What is the fix if this is the case?
完成的
添加一条评论
I solved the problem, but I don't know how. I opened the computer, cleaned it up (it was not so bad after almost 5 years!), disassembled the keyboard and touch pad, cleaned the connectors (already looked clean) and reassembled the computer again. When I restarted the computer, the keyboard and touch pad still did not work.
After reseting the PRAM (or what they call it?) by hold the start button for ten seconds (begin with computer off) they both worked again.
这个答案有帮助吗?
得分 2
1条评论:
Good show! Was the strip a painful experience? I read someone saying half a day for a novice?
完成的
添加一条评论
New battery fixed my problem for the most part. The only times it has lost keyboard & trackpad communication has been a couple of times in the past month when I let the battery die down to nothing, then re-starting the computer with power cable in fixed it both times. No problem if I keep it up over 5% power in the battery and I think the fact the old batter was swollen in the middle and was losing power had something to do with causing this problem more and more often as the batter got older. It would be good if Apple confessed to the cause of this problem and provided sound advice.
这个答案有帮助吗?
得分 2
1条评论:
I thought mine was fixed with a new battery but it went bad again. Replaced the cable running from logic board to keyboard - that fixed it for good.
It's possible that the old cable was OK and simply coming loose, I couldn't really tell, so if you don't have a new cable you can always open it up and disconnect/reconnect cable at both ends and you'll know if it's good or not.
完成的
添加一条评论
Figured mine out a little, my macbook pro was experiencing the same thing. Only conditions under which the keyboard and trackpad would cease responding was when the battery was powering the computer. Whenever I ran it without battery or with battery in but power cable also connected there was no fault ever appeared. I suspect the battery is getting very tired and affecting the basic instructions in the computer. Anyhow I'm due for a new battery as it tells me it needs replacing (2 1/2 years old)so I should know within a week or so that the problem is solved.
这个答案有帮助吗?
得分 1
添加一条评论
How to fix the pad and key board not working problem.
You can connect a use a USB key board and USB mouse to get around the Macbook.
Click on the GO tab
Click on Utilities
Click on Built in key board firmware update.
let it update, once complete. Pad and keyboard should be working.
Rome2563
这个答案有帮助吗?
得分 0
1条评论:
I have same issue, bur Where a can finder this utility? in may Utilities folder don't have this application . Macbook White 2008 lion 10.7.5
Thx
完成的
添加一条评论
添加你的答案
Umesh 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 22
过去 30 天: 79
总计 31,838
