跳转到主内容
Repair guides and support for your Sanyo TV.
360 个问题 查看全部
Powers up with sound but picture takes 15 mins to appear
Sanyo DP26649
Powers up, sound comes on but takes about 15-20 minutes to show picture. Its been doing this for 5 years. Other than that it works great. Id like to keep it if it’s a simple fix. Can anyone lend any advice? Thank you in advance!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
@kcstarr when the screen is dark and you are waiting for it to come on, shine a flashlight beam at an angle against it. See if you can make out shapes, silhouettes etc. If so you know that this is your backlight that is the issue. After that you will have to check the power board and the main board. Check for obviously damaged parts or loose connections. Post some pictures of your boards with your question so that we can see what you see. For now this sounds like either colder solder joints, bad capacitors or bad power Mosfets.
在已经存在的问题里加入图片
这个答案有帮助吗?
得分 0
添加一条评论
Hi @kcstarr ,
Here’s a image taken from the service manual showing the Sanyo Troubleshooting Guide (only for 2009 models) and for the DP26649 (except DP26649-03) model showing the Green Power LED is on but the LCD backlights are not on troubleshooting flowchart.
(click on image to enlarge for better viewing).
Hopefully it is a help
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
kclement20 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 55
