跳转到主内容
Repair guides and support for televisions manufactured by Sony.
748 个问题 查看全部
Half screen upside down. Other function all good.
Sony Bravia TV 55'' ultra 4k
Hi,
My TV got right 25% of the screen firmly upside down and then the next 50% is turning transparent with both upside down picture and stright picture. Then the very left 25% is fine. All other funtions are good.
I bought a new T-con board but the issue remain same. I disconnected the every right ribbon cable from T-com board to the long chip (sorry, not sure the name of it) connected to the screen. The upside down image disappeared. The right 25% of the screen turns white and the image is gradually fading out from left to right. I did the same to the every left ribbon cable. The straight image disappeared. The upside down image is fading out from right to left with the last 25% of the screen white. I swarped the rabbon cables around but didn’t change anything.
I am suspection there is a logic control unit on the chip between the T-con board and the screen is wrong but cannot identify which one. Could anyone please help me to solve the problem?
The chip is 55T08-S01 T550QVF01.1 XL.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
@lleei definitely an interesting error. Since you already replaced the T-con board it does stand to reason that this is caused by a failure of the LCD control board. Looks like your board is a 55T08-S01 Check places like this for a replacement. It is not easy to replace it since the ribbon cables on that should be affixed to the panel via a special bonding process.
这个答案有帮助吗?
得分 0
5条评论:
Thank you for your help. I dont have the tools to reconnect the ribbon cables. Would you be able to know which component on the LCD control board is wrong so that I can replace it.
完成的
I really would have to see the board so that I can at least try to identify what is what.
完成的
Thank you for yor reply. It's a long board. I took 4 pictures for each part. Under the other half of the screen, there is a similar board.
完成的
Hi, I have the exact same issue with 6yr old Sony tv. Did you manage to fix it?
完成的
Mate, it's the problem with the side board. You cannot replace it by your self. You need a big machine for it. I sold the TV to a man who can fix it.
完成的
添加一条评论
T-con board will fix issue. Just had exact issue along with distortion
这个答案有帮助吗?
得分 0
2条评论:
The T-con board was already replaced and did NOT resolve the issue.
完成的
Which board should I replace? EXACT same problem, I am a technician. "Seems" like it would be the LED driver board. I guess I'll order both if no one can tell me for sure which one is bad
完成的
添加一条评论
Which board is it? Main or LED driver board?
这个答案有帮助吗?
得分 0
1条评论:
You can't "swap" cables around. You will blow out something else. You are not qualified to work on the TV.
完成的
添加一条评论
添加你的答案
Raymond 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 1,549
