跳转到主内容
The Asus X555L is a low budget laptop that came out in May of 2015. The model depicted in these guides is X555LA-SI305041, an Intel Core i3 laptop designed to be affordable for consumers. Similar model numbers: X555LB, X555LD, X555LF, X555LI, X555LJ, X555LN, and X555LP
20 个问题 查看全部
CMOS battery on Asus x540y
Where is the cmos battery on Asus x540y taking the laptop apart and can not find anywhere.Please show step by step on how to find and replace.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
最有帮助的答案
Shane Wigum it may not have one. If you removed the motherboard take a look underneath the board. IF you cannot locate it there either it is easily possible that Asus is using a capacitor instead of a CMOS battery. It would get power from the main battery. Anyhow, let us know why you need to replace it and post some good pictures of your motherboard as well as the chassis with your question so that we can give you a more precise answer.
在已经存在的问题里加入图片
这个答案有帮助吗?
得分 1
添加一条评论
hi
there is no cmos battery in your laptop model just the main battery of laptop
这个答案有帮助吗?
得分 0
添加一条评论
请参阅图像内容:
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Shane Wigum 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 21
总计 2,938
