跳转到主内容
The Lenovo P2 is also known as Lenovo P2 P2a42, Lenovo Vibe P2. The Lenovo P2 is an Android smartphone released by Lenovo in November 2016.
13 个问题 查看全部
Why stuck on Lenovo logo boot screen?
I facing this issue while restarting the phone and it stuck on blue Lenovo boot screen for many hours and never start up in to the os. I try hard reset hold Power & Volume Up & Volume Down same issue stuck on Lenovo boot screen.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
2条评论
Hi same issue here , how is your phone?
完成的
my phone hang on first logo (Lenovo P2a42)
完成的
添加一条评论
2个答案
最有帮助的答案
Hi,
If you are holding all 3 buttons together then this is not the right way to do it.
The procedure for a Lenovo P2 hard reset using the hardware buttons is to use only the Power and Volume Up buttons to get into the boot menu area so that the Recovery menu can be selected.
Here’s a link that shows how to do it.
这个答案有帮助吗?
得分 1
1条评论:
if I press volume up and power, it tries to start normal.
完成的
添加一条评论
peksung possibly time to reinstall the firmware. Check this out for the How-to.
这个答案有帮助吗?
得分 0
2条评论:
I have the same problem, Lenovo P2 is stuck in a boot loop.
I can't enter the recovery menu. If I press Volume up and power, it tries to start normally. If I press Volume Down and Up and Power, Phone enters "Bootmode is 'recovery'". After 14 seconds, it tries to restart in the normal startup.
If I press power + Volume Down, it enters a menu to swich between "Start", "Barcodes" and "Power Off". it shows dthe device parameters like serial number, storage, ram and the date of the installed software.
What can I do?
完成的
Hi, we have the same problem with my lenovo p2. It stuck on boot logo and cant even proceed to recovery. Please inform me at newcalderonjoben@gmail.com once you have a solution about this matter.
完成的
添加一条评论
添加你的答案
peksung 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 18
过去 30 天: 75
总计 4,963
