跳转到主内容
加入维修社区 - 创建账户
型号 A1059 或 A1099 / 20, 40, 或 60 GB 硬盘 / 触控转盘
iPod displays folder icon error
I have a 4th generation 20gb iPod (mono) that is displaying the folder error icon. So I have replaced the logic board. I have also replaced the original drive with a iFlash-ATA1 adapter and a Samsung 128gb SD.
After all that, the iPod still displays the folder error and my computer does not see the iPod when it is connected.
Any ideas about what I should/can do next?
Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@sneatonscott your computer most likely will not recognize it since you have no firmware/OS on the iPod drive. I suggest you try it with a regular HDD first and then see what it tells you.
这个答案有帮助吗?
得分 1
2条评论:
I did try that first. I had the same problem. But I’ll try it again.
But if nothing changes, do you have any other suggestions?
Thanks.
完成的
Have you tried to place it into diagnostic mode with a HDD installed?
完成的
添加一条评论
添加你的答案
Scott Eaton 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 311
