跳转到主内容
Wi-Fi版的iPad Mini 2指南。2013年10月22号发布同年11月12号上市。iPad Mini 2就是配备了Retina显示屏的iPad Mini,在更小尺寸的的7.9寸屏幕上拥有和iPad Air相同的像素。
220 个问题 查看全部
iPad A1489 Digitizer Replacement
I use an iPad mini 2, I can not find any replacer for my digitizer anywhere. Those available are those with one pin connectors, the screen that I am trying to replace has two separate sets of pin connectors.
What is the second pin connector for? And can I go ahead and fix the digitizer with more common one pin connector. Will it work?
Update (02/04/2020)
Hey, these are pictures of the inside. Apparently the longer pin connects to the port that is situated higher up.
What is the purpose? And can I use the digitizer with only one pin?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Ree Fagbemi post some pictures of the inside showing us where those cables connect too
完成的
添加一条评论
2个答案
已选择的解决方案
I googled the model number and realized that this is an iPad mini 3 reworked into an iPad mini 2 back case.
The 2 digitizer cables stemming from the front case are the home button and digitizer cables bound together by adhesives.
The fact that there were stuck together is what was confusing.
Thanks guys, I’ll just go ahead and separate the two cables.
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
LCD and digitizer are separate on iPad mini 2 (meaning you can salvage either one given it is unbroken and functional), that long connector sits above short one is to connect LCD.
Make sure LCD is still working, then all you need is the digitizer. Follow the digitizer replacement guide thoroughly on iFixit, and also go over the exhaustive guidelines written by @refectio in his answer to this question: After doing my repairs (battery and screen) I have problems
这个答案有帮助吗?
得分 2
3条评论:
Hey @xingxing, what's the link between a stallion and a gorilla ;-) ?
完成的
@refectio born in the year of the horse and my friends have been calling me gorilla since junior high, according to them I used to be really hairy -_-!
完成的
Hmmm...that makes me a Dragon...maybe I should change my avatar!
完成的
添加一条评论
添加你的答案
Ree Fagbemi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 265
